£850 Max Budget - Little Help
petrow
About a year ago I bought a gaming rig from PCS and now I'm after a laptop. I have £850 as a maximum budget. I don't know a great deal about laptops so I was hoping to get a little help on the build. The only real stipulation is that I would like a Bluray drive, at least 500GB HDD and prefer matt black over gloss.
The laptop will be used for music editing and recording, multimedia, some gaming, internet browsing etc. The last time I actually owned a laptop was probably 6+ years ago and it was so slow to boot up I hated it.
Thanks, Pete
Teaz
Godlike
This laptop should be fine for your needs but gaming is will be at med settings depending on the games played. I'm not sure which blu ray drive you need? just a blu ray drive or a blu ray writer? I popped in the blu ray drive standard if you're not writing to blu ray discs which quite an expensive thing to do.
Chassis & Display
Genesis IV: 15.6" Matte 95% Gamut LED Widescreen (1920x1080) (£79)
Intel® Core™i7 Quad Core Mobile Processor i7-3610QM (2.30GHz) 6MB
NVIDIA® GeForce® GT 630M - 1GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
500GB SEAGATE MOMENTUS XT HYBRID, SATA 3 Gb/s, (7200rpm)**SPECIAL**
DVD/BLU-RAY Drive
SONY BC-5550H 4x BLURAY COMBO DRIVE & CYBERLINK SOFTWARE (£59)
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N130 802.11N (150Mbps) + BLUETOOTH
2 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Battery
Genesis Series 6 Cell Lithium Ion Battery (48.84WH)
Power Lead & Adaptor
1 x UK Power Lead & 65W AC Adaptor
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Total: 804
If your able to stretch your maximum budget a little then I would really recommend the optimus for quite a big boost in gaming power with the 650m which is worth what your getting altogether:
Chassis & Display
Optimus Series: 15.6" Matte 95% Gamut LED Widescreen (1920x1080) (£79)
NVIDIA® GeForce® GT 650M - 1.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
DVD/BLU-RAY Drive
2 x USB 3.0 PORTS + 2 x USB 2.0 PORTS AS STANDARD
Battery
Optimus/Voyager Series 6 Cell Lithium-ION Battery (48.84WH)
1 x UK Power Lead & 90W AC Adaptor
Total: 919
  • Like
Reactions: PCS
petrow
Thanks for the reply Teaz. I always prefer to push my budget and get something better than drop it for something inferior. I'll play around with the second build you gave me and go from there.
Cheers.
