2015 Desktop Moving on, need help with pricing.
steve jones
I have a desktop that hasn’t been doing much for a year.
Purchased in 2015. Will probably need a factory reset and a dust.
Don’t know a price just yet, will have to make sure it still in working order.
Any idea on how much I should sell it on for roughly ?
Specs are
Showing Order Reference 825011
COOLERMASTER CM690 III ADVANCED CASE (GREEN)
Overclocked CPU
Overclocked Intel® Six Core i7-5930K (3.5GHz @ MAX of 4.4GHz)
OC Settings
Show/Hide
ASUS® X99-S: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
16GB KINGSTON HYPER-X FURY DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 980 Ti - 1 DVI, 1 HDMI, 3 DP
2nd Graphics Card
NONE
3rd Graphics Card
NONE
480GB KINGSTON HYPERX SAVAGE SSD, SATA 6 Gb/s (upto 560MB/sR | 530MB/sW)
2nd Storage Drive
2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
3rd Storage Drive
NONE
4th Storage Drive
NONE
NONE
1st PCI-E SSD Drive
NONE
RAID
NONE
DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
External Hard Drive
NONE
NONE
CORSAIR 1000W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H60 Hydro Series High Performance CPU Cooler
Change to: Corsair H80i GT Hydro Series High Performance CPU Cooler
Fan Controller
NONE
Extra Case Fans
2 x 12CM Black Case Fan (configured to extract from rear/roof)
Asus Xonar DGX 5.1-Channel Gaming Audio Card
WIRELESS 802.11 AC1900 1,300Mbps/5GHz, 600Mbps/2.4GHz PCI-E CARD
Wireless Router/HomePlugs
NONE
MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Capture/Streaming Cards
Hi Steve, I’m afraid we’re not really able to advise on this one. Your best bet would be to have a look on eBay, Gumtree and the like to see what similar setups are going for. It’ll likely fetch less than you’d be hoping for, second hand systems depreciate in value massively as tech is continually being updated and improved upon, rendering older components somewhat moot.
