Specs (budget is £1600 with very little headroom, £30-50 at the very best)
Case: Coolermaster Mastercase PRO 5
CPU: i7 7700 (non-k)
Mobo: Gigabyte Z270X ultra gaming: ATX, LG1151
Ram: 16gb Corsair Vengeance DDR4 3000MHz
Graphics card: GTX 1080 8Gb
1st storage drive: Samsung 850 EVO 250Gb
2nd storage drive: 1Tb WD black
PSU: Corsair 650W TXm series Modular 80+ GOLD
Processor cooling: Noctua NH u14s
Thermal paste: Arctic MX-4 Extreme thermal conductivity compound
Extra case fans: 2x 120mm case fans
Wireless card: 802.11N 300Mb/s
Some questions I have:
Is the NH U14s enough for an i7 7700? I couldn't find any builds using it, and I know that the 7th gen i7 CPUs run quite hot.
What version of the 1080 is typically used on the site, since i'm aware you're not allowed to choose the card, but I realised it's not very expensive on here, only ~£470, which I found stunningly cheap. Additionally, will this run cool enough in my system? Is it also just a lottery of which card I get? E.g., will I get an asus turbo 1080 or a ROG STRIX?
I've heard some issues exist with corsair PSUs, and I was wondering if that's just a rare occurrence? I actually have a 750W TXm in my PC which makes a low grumbling noise from time to time, and actually can be felt vibrating quite strongly, but it's never felt to cause any direct issues, so hasn't bothered me much.
Lastly, which is better out of the ASUS ROG STRIX Z270H and Gigabyte Z270X Gaming ultra? Does it come down to basically a cosmetic option? The Z270H is £20 cheaper.
Side notes:
I don't know a thing about actually doing anything with the insides of my PC by hand, so anything that requires that would be pretty painstaking for me, since I don't really trust myself enough to do it.
I really would like to avoid water-cooling, because of the risks of leaks, I know that they are extremely small, but I'd like to avoid them nonetheless.
Any additional observations would be very welcome and appreciated!
Side notes:
