32gb RAM 3600mhz issue..
BT81
Good evening all.
I've a x570 AUS Tuf motherboard and currently rocking 16GB 3600mhz RAM made up of x2 8GB sticks.
- I have bought some more, another x2 8GB, and so far I've been unable to get a stable PC. I.e it often BSOD.
Any tips I can try?
Good evening all.
Any tips I can try?
Can you post your full specs from the order page?
What program is it that requires the extra RAM?
Did you source the same RAM? You can identify it by the part number in CPU-Z on the SPD tab.
Would have suggested 2x16gb. Getting the same timing across all 4 sticks can be tricky if they aren't the same CAS rating.
Full spec and the model of the RAM you bought if you know it :)
