3d MARK 11 help
KOOZIE-SPARTAN
My new pc came 3 days ago, and I went on 3d mark 11,
it said this.
IT LOOKS LIKE YOUR PC SHOULD SCORE BETTER.
With a red battery symbol for the overall score and graphics score.
I downloaded and installed the latest 670 driver, what am I doing wrong?
I have sli 670 also.
keynes
It could be an old version of 3dmark11, had the same issue as well. Unless it prevents you from running any applications/games i wouldnt worry about it.
baron75mk2
Banned
with GTX 670s SLI , there should be no game at all you cant achieve 60fps at all times in ( not much point in higher fps than that) ,
i wouldn't worry 3d mark 11 inst the most reliable of benchmarking apps - it dragged mine down to 15 fps (that's just a joke & cant be right at all) .
Try mark06 or vantage ( sure they are not DX11 , but they give more accurate results in my opinion)
I find the best way to bench is to knock off v-sync & bench using actual games & compare this to other setups in pure FPS terms - i wouldn't get to bogged down in benching , just enjoy those lovely 670s in SLI with smooth gaming across the board :yes:
