4 pin Molex to 6 pin pcie
Sleinous
OK simple question.
Would the following products work for a GTX 465?
http://www.xpcgear.com/dual-8-pin-6...wer-adapter-cable-4-pin-molex-video-card.html
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=25358
Which is better?
Basically the PSU in question only has 4 molex, and if I use the regular 2x Molex to 1x 6 pin pciexpress power cable then I use ALL molex for that purpose and will have none left for SATA etc (only has 1 SATA cable and need another for the DVD).
Would this one work for a GTX 465? Im a bit hesitant, especially as the first link only has 3 metal prongs in one of the molex and 2 in the other. (The one infront of me for just 1 pciexpress has 3 prongs in each of the molex) and this is supposed to be for 2x pciexpress.
Any ideas would be welcome.
PCS
Administrator
Staff member
Your second choice should be fine, providing the PSU you're using will be powerful enough to handle your PC + the GTX 465 (about 120W).
