Dazzler_3000
For the last 2 weeks or so sometimes on startup my PC is beeping 5 times and then running normally. When this happens there's also a red light on the motherboard in the bottom right hand corner (photo included). I've tried googling the issue but I get a variety of possible causes and my PC knowledge isn't great so I don't want to go fiddling with stuff and creating more problems.
One thing I've tried is removing and reconnecting the RAM but that doesn't seem to work (RAM appears to be working fine as far as I'm aware). PC specs are below:
Overclocked Intel® Core™ i7-8700K Six Core (3.7GHz @ up to 4.8GHz)
Gigabyte Z370 AORUS Ultra Gaming: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE RGB DDR4 3000MHz (2 x 8GB)
EVGA RTX 2080XC
500GB Samsung 860 2.5" EVO SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
Corsair H100x Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
Any advice on what it could be and how to resolve it? I'm not sure if it's linked, but about a month ago I dusted the computer and I'm thinking I may have knocked something loose but I've checked the connections and they all seem to be fine. If this issue is tied to one specific thing though I can check that connection in isolation.
Thanks very much
EVGA RTX 2080XC
Thanks very much
