5800X idle temps way high, doesn't seem to underclock?
aroobra
ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
2nd M.2 SSD Drive
Received this build yesterday and I've noticed that with the H115i fans set to Quiet in iCUE my *idle* temps are above 60 degrees which seems crazy even for a Ryzen processor. On the balanced setting (which is very loud) idle temps are around 50c. In HWiNFO my CPU always seems to be boosting the clocks randomly even when not doing anything which probably doesn't help this. The only way I found to make it underclock at all was with the "power saver" plan in Windows but this doesn't seem to work correctly for boosting back up when gaming (even with min and max processor state set to 5% and 100% respectively inside the plan options.)
What do you have running at idle and what do the temperatures go up to when the cpu is running at 100% (try a stress test such as Aida64)
sck451
Are you sure it's actually idle? If you're doing something like updates or game downloads in the background, the CPU could be working surprisingly hard.
It won't be idle if it's a new PC, the indexing will be running full tilt for the first few days, plus Windows updates alone will put quite a load on the CPU.
