A couple of build questions?
mitchm75
Will be buying an Optimus V very soon. I'll be using it to play games such as Civilization V and Skyrim aswell as watching HD movies and TV.
In regards to RAM, is it better to go for the Samsung 1333MHz 1x8GB or the Kingston 1600MHz 2x4GB configuration? Will there be any noticeable speed difference? In terms of future upgrading there are only 3 slots so the Samsung 1x8GB would be less fiddly.
Also is Windows 7 or Windows 8 better? I realise this is pretty subjective, but is there any performance difference when running games between the two? Will Windows 8 be dumped by Microsoft soon or will Windows 7 be no longer supported with updates?
My budget is pretty much maxed out, but are there any further improvements that can be made?
Many thanks, Matt
Chassis & Display
Optimus Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (1 x 8GB)
NVIDIA® GeForce® GTX 765M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
750GB WD SCORPIO BLACK WD7500BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
DVD/BLU-RAY Drive
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N135 802.11N (150Mbps) + BLUETOOTH
Battery
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
1 x UK Power Lead & 120W AC Adaptor
Genuine Windows 8 64 Bit - inc DVD & Licence (£79)
NO OFFICE SOFTWARE
Keyboard Language
OPTIMUS SERIES UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
Webcam
Insurance
Standard Build - Approximately 9 to 11 working days
Quantity
1
Price: £883.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/optimusV-17/WFpUGFX9C_/
keynes
No significant difference between 1333mhz and 1600mhz memory same as with windows 7 vs windows 8 in terms of gaming performance.
guartrainer
Hi Mitchm75.
I originally ordered my Optimus V with the Kingston 1600MHz 2x4GB configuration, but I was informed by PC S. that I had to change my order to the Samsung 1x8GB due to "compatibility issues".
On the plus side, 1x8 gives you a free slot for later expansion - the change considerably lengthened my build time though...
I'm on Windows 7 playing Skyrim and Batman: Arkham City - no problem. Hope this helps you.
Cheers,
G.
mitchm75
Thanks guys, you've both helped. I've gone ahead with the purchase as specified above.
And now for the wait.......
