Hi all. so am tuning the fans up to find a good balance for noise and performance and decided to make my own fan curve to help with that . In msi it says the temp limit for my 3080 is 83c which i believe is when it would start to throttle back . If i let the gpu do its own thing it goes to 75 percent fan at 74- 75c at full load . If i set a curve in msi and drop the fan percentage to max out at 70 the gpu is 76c on full load for example and of course a little quieter . What i am asking is it ok to play about with the fan percentage and maybe lower and get little higher temp as long as the max temp of the gpu does not reach the 83c to lose more noise if i wanted , or is that a bad thig to do . Thank you
