SmokeDarKnight
But if no one is in the room does the machine exist at all?
Too true. And if a man speaks and there's no woman there to hear him is he still wrong? :wacko:
If it's a sealed room, I don't think there is a stable end result - it would continue to heat up. If one takes fractionally longer, then at any given time, it's at a lower temperature.Since we are talking real world the answer is fairly simple, the energy output is the same so while it might take fractionally longer to heat up (as the water absorbs the energy) the end result is identical.
I think you should really read the post from the beginning, including the Facebook conversation. It was not a science question paper and should not be treated that way. Simply a passing statement on Facebook. It was a bit of fun. The original question came about as guy on Facebook said he got a watercooler for his GPU and his room is now considerably cooler than with air cooling. He got the watercooler as he stays in a hot country and had the idea that as the GPU remains at a cooler temperature under water as apposed to air, this would keep his room cooler too. That person and others argued this case. Whereas others stated there will be very little difference.
I stuck it on here to get people opinions on this. I am not interested in 0.5 degree differences or overclocking, room size, vent placement or the size of the windows. Its just a comment that we make a decision on based on the information we have, for fun!
So.....I can stop calculating the relativistic effects of the different speeds of air molecules and the non-linear (chaotic) air flow for each cooling system then?
