Afternoon. I've been thinking of getting some new fans as I currently have a couple of generic PC Specialist ones (one on the reart and the other on top). Only the pump and RAM have RGB so the case is dark (like my life!). Plus we all know that the more RGB the more FPS so I'm currently missing out
I've seen the below on Amazon and Corsair's site but I thought I would get your opinion on which is the most suited and if there are any others you may recommend.
PC specs:
ASUS® TUF GAMING X670E-PLUS WIFI (DDR5, PCIe 5.0) - RGB Ready!
20GB AMD RADEON™ RX 7900 XT - HDMI, DP - DX® 12
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
CORSAIR iCUE H115i RGB PRO XT Hydro Series High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
Thanks
PC specs:
Thanks
