Advice for buying a 4K Monitor?
PCUser1990
Hello there!
Currently I am running a GTX1080 which is really going to waste gaming wise on my Acer Predator 35" Widescreen, only running at 1080P. Does anyone know of a good 4K monitor for up to / around £400 that would serve me well? Cheers!
If you can, I'd say pip the budget by £100 and get the predator XB281hk which has Gsync. At 60hz (which all affordable 4K monitors are) you REALLY want Gsync for that added smoothness. I've got one and would vouch for it.
You can find it for just under £500 if you shop around.
hey try Dell Ultra HD 4K Monitor P2415Q 32-Inch Screen LED-Lit Monitor
Is that not a 24" monitor? The first two digits of a monitor's name often relate to the screen size.
A quick google suggests it's 23.8".
Which one were you thinking of mate?
