Hi, I am looking to buy a gaming/work desktop pc, and even after spending a sizeable amount of time reading about different components, I still cannot make up my mind with regards to some of them, so I thought I would ask for advice.
A bit about the use case: I would mostly use this pc to play new AAA games, and would like the quality to be very good (I don’t need Ultra in everything) and with good fps. To a lesser degree, I would also use it for work, which is game development, programming, and image/video processing (working with RGB-Depth cameras, Hololens, etc). Maybe also a bit of VR gaming. I currently have a 27 inch 1440p monitor that runs at 70Hz. My budget is about 1800 eu, maybe 2k eu if it would make a big difference.
Some doubts I currently have. I’ve been reading about the i7-8700k vs Ryzen 2700x, and I think I am leaning towards Ryzen, but I could be convinced otherwise. Maybe the i7 is overkill, for what I need, I don’t know. With regards to the graphics card, I am thinking on probably getting a GTX 1080, but maybe a 1070 would do the trick? Or even a Radeon? My monitor has freesync, but I think NVidia has better cards. I would also prefer air cooling rather than AiO systems, and I saw that Noctua has the best ones, but again, maybe a cheaper option would suffice?
Considering this, I would appreciate it greatly if someone could help me with a good build based on my expected use, or just some advice with respect to the components.
Also, I just saw that you can find some builds in the review section of the website, and they seem considerably cheaper than when you build a similar one. Is this accurate? Or is it just me? I saw on the forums people suggesting the Vulcan X, which seemed nice, but I would like faster RAM. When I tried to build a pc just like the Vulcan X, the price was much higher, but maybe I was not doing something right.
Thanks a lot for any help you can provide.
