Advice on build | PCSPECIALIST
Advice on build
CCON
Hi all ,
Looking for build advise on a desktop
80% of the time it will be used for gaming the rest low resource programs and tasks
I will be keeping my current monitor. Acer XB241H 24" Full HD [email protected]
16:9 1ms GTG overclock 180Hz. TN G-Sync
Would like operating system on separate drive and dont need a very big secondary ( don't store a lot on my pc's currently getting on fine with 500Gb)
Extra ram is future proofing.
Budget was E1500 but iv gone over
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/3XBYAGUKH7/
PCS P209 RGB MID TOWER CASE
AMD Ryzen 5 3600X Six Core CPU (3.8GHz-4.4GHz/36MB CACHE/AM4)
500GB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
Firefox™
Keyboard & Mouse
Phantom RGB 88-Key Backlit Mechanical Keyboard (Red Switch)
Standard Build - Approximately 21 to 23 working days
Price: €1,625.00 including VAT and Delivery
CCON
Hi Nursemorph,
Thanks for the quick reply . I have edited the original and added the information you requested.
I currently play a nice bit of Star Citizen ( not here for the "it's a scam " discussion I enjoy it) . In its current unoptimized state it uses all of my 16gb of ram.
Thanks for the help
Few tweaks....
Agree regarding the RAM. I doubt that Star Citizen is actually bottle necked in any way by 16GB. It may be allocating it, but it won't be held back in any way. It would be far more relevant to opt for faster RAM than more RAM, when considering the future.
Moved a few things around. If you want to save further the PCS M2 500GB drive would be a fine choice.
CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
STANDARD AMD CPU COOLER
Firefox™
Keyboard & Mouse
Price: €1,545.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/GhQHqYzd5V/
CCON
Hi Scott,
Thanks for the reply
I read you build guide which guided me in a lot of the choices you see before you.
So you think I'll be fine with standard cooling .ya I wasn't sure.
And the 570 motherboard was again purely based on your build guide.
I don't mind going 1 or 2 hundred over the E1500 if it means a rig that will stay current for longer .
Hi Scott,
For gaming there's no real gain with the 570. You will notice that most gaming builds I recommend have the B550 on there. The only reason to consider the 570 is if you are planning a significant CPU hike in the future (12 core +)
The B550 is actually the most recent board. Should be good for at least one and maybe 2 generations, as the X570 will be too.
CCON
Thats great Scott and Nursemorph.
Will make the changes you recommend and will hopefully put in the order come payday at the end of the month
