Advice?
JaM1e
Hi
So it's that time again where I'm looking to build a new rig. The below is what I'm potentially looking at, however need some advice. I've went for the Titan X however I've not gone for a monitor that displays 4K.
The reasons behind this is I prefer a 144hz refresh rate for competitive gaming, that's not to say I won't go for 4K at some point.
So I guess my questions are is it worth going for the Titan X or either a different card / wait for new cards?
Should I just bite the bullet and go 4K now? I'm going for a beasty machine that will last me a while hence the overkill.
Intel® Core™i7 Six Core Processor i7-4930K (3.4GHz) 12MB Cache
COOLERMASTER COSMOS SE GAMING TOWER (Windowed)
ASUS® P9X79 LE: INTEL® SOCKET LG2011
16GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (2 x 8GB)
12GB NVIDIA GEFORCE GTX TITAN X - DVI, HDMI, 3 X DP - (PRE-ORDER ONLY)
1st Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
2nd Hard Disk
4TB WD CAVIAR BLACK WD4003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H100i Hydro Series High Performance CPU Cooler
Creative Sound Blaster Z 5.1 PCI-E Soundcard - OEM
Monitor
BENQ XL2720Z 27" W, 3D LED GAMING MONITOR
Keyboard & Mouse
Corsair Gaming K70 Fully Backlit Gaming Mechanical Keyboard
Mouse
LOGITECH® G502 PROTEUS CORE GAMING MOUSE
Gaming Mouse Pad
SteelSeries 9HD Gaming Mouse Pad
Speakers
Creative GigaWorks T20 Series II 2.0 Multimedia Speakers
Cable Tidy
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
JaM1e
Also I must add can anyone recommend a quiter CPU Cooler that just aw good? I find the H100i to be very noisy.
keynes
For 1920x1080 it is massively overkill. You could consider the GTX 970/GTX 980
JaM1e
Thanks for the prompt reply. Would it be worth SLI X2 980s? Like I said at some point I'm going to move to 4K monitor. I might just go for it now. Wish they'd release a 4K monitor capable of 120hz / 144hz refresh rate :(
JaM1e
I've ordered the above system I'm now contemplating switching th3 monitor for the Asus ROG... would this be a better monitor to use along side the Titan X?
Also when I checked switching to it there was a message about connections that may be required? Has anyone got the rog who can tell me a bit more about it?
