Advice
Hello, I am looking for a laptop and am looking to spend around £1200, it will be used mostly for gaming and the occasional work stuff could someone help with a build please
TIA
TIA
What do you mean by "work stuff", you need to list the programs you're using, work stuff could mean anything at all What kinds of games also?
Just Google documents, games like Day Z, call of duty, hell let loose! It will mainly be used for gaming. Thankyou
So laptops are far more expensive than desktops, and laptop GPU's are a few tiers down from a desktop GPU so a desktop 4060 would be roughly a laptop 4080
PCS have also run out of stocks of most budget options, your only options would be the 1650 or the 3050, both of which are poor.
Your budget is extremely restrictive for a custom laptop to get anything worthwhile to be honest, basically you'd never get anywhere near max settings, you'd have to reduce to medium probably, and that's now, within a couple of years you'd have to get a replacement.
I would suggest getting a branded laptop as they'll be far cheaper for equivalent specs.
This would be a 1080p build, it's slightly over but I wouldn't go under this or you sacrifice the platform
LIAN LI LANCOOL 205 MESH C GAMING CASE
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s)
32GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 16GB)
8GB AMD RADEON™ RX 6650 XT - HDMI, DP - DX® 12
512GB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
ONBOARD 2.5Gbe LAN PORT
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Standard Build - Approximately 11 to 14 working days
Price: £1,233.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/xbCAGEUHtW/
