Any Advice will be appreciated
Hey Folks, I'm new here. Any advice if the specs below are good?
COOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE
8GB AMD RADEON™ RX 5700 XT - HDMI, DP - DX® 12
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
NelDio
I would change the Ram to 3600mhz and power supply to 550 as you dont need all that power, and add a 1TB hard disk, the rest seems ok to me!
But if u have a budget then don't add the hard disk!
Thank you
Thank you
Thanks, I've selected the 650W because the recommendation for RX 5700XT from AMD site is 600W. Will I not encounter any issues with 550W PSU?
Before we can suggest a system we need to know a few things:
What's your max budget?
What monitor are you pairing it with, what resolution and refresh rate or make and model if you're unsure?
What's the build for?
