Any help appreciated....
Jimbhoy
First thankyou to the PCS elves for getting my rig into pre-prod'n so quickly.
2ndly, looking to purchase 2nd laptop as pressie for friend.
I'll be able to claim the VAT back but not looking to spend much over £500 (ex vat).
Not for gaming, just for general usage.
Obviously not top of the range but just for general usage (web-surfing etc).
J
LFFPicard
Godlike
Before I recommend anything I want to make sure the VAT is clarified.
As I have mentioned in a previous post on the forums: http://www.pcspecialist.co.uk/forum...Custom-Built-PC!&p=50674&viewfull=1#post50674
I would be very careful with the VAT claiming you are talking about as if you do not do it right then you could cause a lot of problems so I suggest reading up on the restrictions on VAT claims or clear it with the companies financial director.
Here is the regulations on VAT reclaiming: http://www.hmrc.gov.uk/vat/managing/reclaiming/reclaim.htm
Specificley:
When you cannot reclaim VAT
There are a number of situations where you cannot reclaim VAT that you have paid.
You cannot reclaim VAT paid for goods and services that are used for non-business activities. This includes:
* goods and services that are bought for your personal use
* cars that are not used exclusively for business purposes (and any fitted accessories and delivery)
* goods and services for non-business use bought by charities or not-for-profit organisations
Jimbhoy
Hi LFFPicard ,
yes VAT is clarified. Double checked it with accountant but will have to get friend to order it in his name as can't claim VAT back on 'gift' (he's not a charity).
So with VAT @ 20% and a £500 (ish) budget, that'll give £600 to play with.
Have some rep anyway!
J
Teaz
Godlike
This will cover that area for general everyday use :):
Chassis & Display
Enigma III 520: 15.6" HD LED Backlit Widescreen (1366x768) Super Clear Glossy
Intel® Core™i5 Dual Core Mobile Processor i5-2410M (2.30GHz) 3MB Cache
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 2GB)
nVIDIA® GeForce® GT 520M - 1GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
250GB WD SCORPIO BLACK WD2500BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
DVD/BLU-RAY Drive
Integrated 3 in 1 Memory Card Reader (SD, MMC, MS)
Bluetooth & Wireless
GIGABIT LAN & WIRELESS 802.11N CARD (STANDARD)
1 x USB 3.0 PORT + 2 x USB 2.0 PORTS AS STANDARD
Battery
Enigma III Series 6 Cell Lithium Ion Battery (5,100/5,200 mAh)
Total: 616
Jimbhoy
Thanks Teaz,
pretty sure I mentioned "free beer" in my very 1st post for any help.
Presuming you're old enough....
