Are these ARGB fans AURA sync compatible
Are PCS SPECTRUM II ARGB MID TOWER CASE fans compatible with AURA sync
  • Yup
    Votes: 0 0.0%
  • Nope
    Votes: 1 100.0%
  • Total voters
    1
B4zookaw
The Spectrum II is a new case to the lineup, so we don't have much info on how case fans are wired. Normally it's one of two ways:
  1. Case fans are connected to an ARGB controller, that is in turn connected to the Reset button on the case. Pressing the Reset button cycles the fans through a number of preset RGB patterns
  2. Case fans are connected via a splitter cable to an ARGB (3 pin 5V) header on the motherboard, and are controlled by the motherboard's software (Armoury Crate for Asus for example).
Even if the case comes with the fans connected with the first approach, you could easily change to the second method yourself, provided motherboard has an ARGB header, which pretty much every recent board does.
Ernie
Thanks, I'll keep your advice in mind 👍
