Best system for £1200
Scottd
Hi,i am a relative noobie when i comes to custom computers and i have recently been looking for a system that will be able to play most games whilst also being fast and reliable. I was considering the following set-up and was a little unsure as to how much of an advantage the ssd give on start up and the running/ opening of applications. I am also torn between the gpu whether to go with the radeon hd6970 or the gtx 570. Any advice on the set-up would be greatly appreciated.
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Memory - 1st Hard Disk
1TB SATA-II 3-Gb/s HARD DRIVE WITH 32MB CACHE (7,200rpm)
SSD CACHE DRIVE
20GB INTEL® SSD 311 SERIES - CACHE DRIVE FOR SYSTEM / 1st HDD
1st DVD/BLU-RAY Drive
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£42)
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Network Facilities
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16)
tom_gr7
Life Serving
this is 1223 and gonna smash any game you throw at it. (would put money on it, if had some)
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics gonna give you similar levels of gaming than the 2600,
1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready beast, no need to say more
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) nice, they at a very good price, same as 1tb, wouldnt bother with the caching drive, rather the 580
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£42) if you dont need the blu ray, remove it, and up the case to the cm690 II
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19) no need for titan, is massive, is very good but will force pcs to remove ya side fan cause its so big, so stick with this cooler, which to be honest is perfectly fine.
Network Facilities
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£16) this wil lbe placed above the 580, a pci card would be placed below, so may slightly get in the way of the ya 580 fans, sucking in air.
NO OFFICE SOFTWARE
NO ANTI-VIRUS SOFTWARE try free stuff first, avast, MSE, avg etc etc
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5) important, don't forget
Quantity 1
Wozza63
Biblical Poster
personally if you get the CM690 II case then i will definitely recommend the fan controller, as it offers 5 extra fans and this case definitely has some free slots
