Bluetooth Speakers Pairs But No Audio
qinen
I am using the Optimus V and opted for the most basic LAN adapter (that doubles as the bluetooth as well?)
As far as I know it's the realtek one.
I recently bought some bluetooth speakers and tried to pair them with my laptop but couldn't. The speaker is listed merely as A2DP device.
So basically I was wondering if the Realtek adapter supports A2DP at all? And if so, is there a driver update that needs to be done here to solve the problem?
steaky360
I'd have thought you might need to install the drivers for the speakers maybe? Rather than simply installing any new drivers for the Bluetooth device (which is not necessarily a bad idea in any case!).
I have a similar issue
i have been trying to get my nokia bh-905 to connect to the intel bt ac-7260 of my new laptop
it recognise the headphones , but does not connect . it always says A2DP connection fail.
i have tried to connect via a dongle and it works fine . I strongly beleive as the A2DP is not included in window 7 that s the issue
there is nothing available on the intel website . It s very frustrating. I tried to go around via toshiba stack or bluesoleil but none of them recognise the intel bluetooth hardware.
Any input , work around would be appreciated. I feel cheated to have bought a brand new wirless/bt4.0 and have to use an external dongle do connect the same headset that works seamlessly with my tablet and phone .
