Hey guys,
I've done all the troubleshooting I'm capable of and none have helped, basically I get BSODs when playing GW2, and so far, nothing else has triggered it, although the only other game I'm playing on my laptop is Borderlands the Pre-Sequel, and that's not caused any issues. I've tried a fix I saw online as well about expanding the nvlddmkm.sy_ or whatever, and initally it seemed to decrease the frequency, it's back to it's "normal" self now. I've done a fresh install of Windows 7 and that's not helped either. I've recently cleaned out the filters and fans of my laptop as well so I know there's no issues there. As for drivers, I've tried loads of different ones, they all end the same way.
On Fri 31/10/2014 00:59:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\103114-7534-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x91DC84)
Bugcheck code: 0x116 (0xFFFFFA80120E0010, 0xFFFFF8800F932C84, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 344.48
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 344.48
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 344.48 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
These are my temps while playing:
GPU 67
CPU 65-72 between cores
I don't have an external hd/ USB stick to do a memtest sadly.
Any help would be appreciated. Thanks!
GPU 67
