Budget OC and Monitor for FS2020
Hi there
I want to buy a budget PC and monitor for my brother in law as he’s mad keen on Flight Sim and his current PC won’t run FS2020.
ive looked at some of the next day delivery PCs and came across the following which I’ve paired with an AOC 24” monitor which looks quite good. 24“ is the max size of monitor that will fit his room.
Absolute max budget all in is £1,500 .
Would this be a good buy? I tried to post the spec to the forum but wouldn’t let me - not sure if that’s because it’s a pre configured build?
grateful for your feedback.
Donald
8GB AMD RADEON™ RX 5700 XT - HDMI, DP - DX® 12
Get Godfall and/or WoW:Shadowlands w/ select AMD Radeon Graphics
STANDARD AMD CPU COOLER
LED Lighting
50cm RGB LED Strip
Monitor
AOC G2590PX 24.5" 144Hz Gaming Monitor
QTY
1
£1,142.50
ex VAT
£1,371.00
inc VAT and Delivery
Order by 3pm (Mon - Fri) for same day dispatch.
Cheers Mate and no, there is no rush. Just used the pre set config as somewhere start with. Will defo go with your suggestions as happy to max out the budget. I know the monitor size is a bit of a pain but if I got him anything bigger my Sister in Law would go mental!
cheers
Donald
D
Deleted member 17413
Guest
27 isnt that huge a leap from 24... Its only like 1 inch taller and a couple wider I reckon you could easily get away with it just by pointing to 1440p and how great the flightsim is at that resolution.
Worth remembering that FS2020 has literally a real global map... Imagine the sights/destinations she could peak at in real clear images, scout out possible holiday destinations... There are ways to sell this.
