Building My First Gaming Pc, Help
Nohackz
Hi, Im new to the whole building pc malark and hoping you guys could shear some of your expertise, so ive been scanning the web all day trying to find components to build my ideal gaming pc but im not sure if these parts are any good or whether im missing any parts out so any advice would be very helpful
SPEC
CPU: AMD FX 8150 Black Edition
GPU: 2GB XFX Radeon HD 7850 Core Edition
Motherboard: Asus M5A78L-M
Ram: DDR3 2400MHz 8GB Dimm Unbuffered 10-12-12-31 Vengeance Black Heatspreadersupports
PSU: be quiet! BN107 Pure Power L7 630W Power Supply
Case: Aerocool Syclone II Gaming Case
sted
I think you'd benefit from a PCS specific build, tbh (I don't work for PCS or anything but they have very competitive pricing). Might I ask your budget, intended use and what not? If you do choose to go for a PC from here, be sure to spec it in the configuration, make sure everything is compatible, click proceed with order then post to forums, copy the whole spec including the link that comes with it and paste it all here, helps for us to make changes and suggestions that will help you.
