Building my first PC help (Gaming)
MathersMahmood
Hi everyone hope your all well. This is my first PC and im quite excited to have it built. I will be using it for gaming and for university work. One thing to note is that i dont know if i will be over clocking it but ive chosen the liquid cooling system (H80i) to keep it cool because my room can get pretty warm and also i do not know if that super quite copper fan that PC Specialist provide for £19 is good enough to keep my PC cool.
Please let me know what you guys think. I've also chosen the Motherboard with the wifi built in instead of getting those adapter things.
Thanks
ZALMAN Z11 PLUS BLACK MID TOWER CASE
Intel® Core™i7 Quad Core Processor i7-4770k (3.5GHz) 8MB Cache
ASUS® Z87-PRO: USB3.0, SATA 6GB/S, XFIRE, SLi, WiFi
16GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 8GB KIT)
3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk
3TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive
15x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£79)
Corsair H80i Hydro Series High Performance CPU Cooler (£69)
Network Facilities
1 x 2 Metre UK Power Cable (Kettle Lead)
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence (£79)
NO OFFICE SOFTWARE
Monitor
IIYAMA E2773HDS-GB1 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080
DVI-D & HDMI Monitor Cables
1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£8)
Keyboard & Mouse
Razer® Black Widow 2013 Ultimate Mechanical Gaming Keyboard (£119)
Mouse
Razer® Taipan Expert Ambidextrous Gaming Mouse (£75)
Gaming Mouse Pad
Razer Goliathus Omega Control Mouse Mat (£14)
Speakers
LOGITECH Z323 2.1 SPEAKERS - 30W RMS with 360 Degree Sound (£44)
Surge Protection
6 Socket Compact 2M UFO Surge Protector (£9)
Quantity
1
keynes
Without overclocking the cpu the triple copper heatpipe should be as good as the hydro corsair coolers.
I'd suggest at least silver warranty and if you are planning to SLI you need to upgrade your PSU.
MathersMahmood
Thanks. I will change the cooling and the warranty. I dont think i will be going SLI anytime soon but do you still think i should upgrade the PSU?
keynes
If you are not planning to sli you don't need to upgrade the psu, you could downgrade the motherboard instead. What sort of uni work are you planning to do? CPU intensive?
MathersMahmood
I'm going to be doing computer science. I code this motherboard because it has the built in wifi and the other ones don't.
keynes
If the only reasons you have chosen the pro version is for the wifi built in it will be cheaper to get a different motherboard and add a wireless card. A pair of homeplugs should provide a more reliable connection.
MathersMahmood
I don't really understand the home plugs and what they are and I don't like the look of the wireless cards that have those antenna sticking out.
keynes
The motherboard with built in wifi will also need an anthena to be attached.
Homeplugs should offer a more reliable connection to the wireless connection, you need a pair. One close to your router and one close to your computer.
MathersMahmood
I assumed that the wifi motherboard would provide me with the wireless internet just like a laptop?
Rakk
The Awesome
Then why do i need the antenna and the plugs for?
because my pc will be in the same room as the router anyway so it shouldn't make a different to the connection?
The Wifi on the mobo still has small antenna that need to be used, it is not like a laptop that requires no antenna.
You might be fine without if you are close, but I wouldn't bet on it :)
keynes
As far as I know there are many things affecting the connection of a wireless card. I have an Asus Zenbook laptop and I find the wireless on it very unreliable (next to the router), I had to purchased a pair of homeplugs because the connection kept dropping.
MathersMahmood
Oh ok. Can a home plug off a extension lead socket? or does it have to work from an actual mains socket?
MathersMahmood
If i get a home plug and connect that to the computer then will i need an antenna?
MathersMahmood
No antennas with homeplugs, one is connected to the computer using an Ethernet cable and the other one is connected close to the router.
Intel® I217V Gigabit LAN / Speedy Wi-Fi 802.11 a/b/g/n supports dual frequency band 2.4/5 GHz
This is the wifi on the Motherboard. I thought that was good enough and i didn't know that i needed another antenna.
Can i connect a home plug to an extension cable socket or do i need an actual wall socket?
MathersMahmood
Yes it will be fine, the antennas you need for either the wireless card or Motherboard WiFi are always included with your order anyway, you would never need to buy extra ones.
Ah ok.
Thanks for the help guys much appreciated.
What do you think about my build then?
