calling for expert advice
faihaf
i am looking for a new pc for gaming I mainly play fps such as bf4 i want to spend as little money as possible please
this is the pc i bought 4 years ago from pc specialist if i can use any of these part and save money that would be great.
before you ask this current setup is gone faulty i thought it was the mb so i bought a 2nd hand ASUS P8Z68-V /GEN3 SOCKET 1155 MOTHERBOARD but after installing it pc is keep crashing with blue screen and i cant figure it out what is wrong with it so thats why i want to get a new one
so please help me thanks
old pc spec
COOLERMASTER HAF 932 FULL TOWER GAMING CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card
1st Hard Disk
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£162)
TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£19)
mrlucamk
Imo the Power supply + CPU cooler + Ram is good and you should keep, but i'm not the best for computers so thats just imo
mantadog
Superhero Level Poster
It might be easier/cheaper just to fix the fault with the current rig as it looks pretty capable to me.
If you can post some more info on the faults we can possibly help you diagnose the issue?
faihaf
well my pc is keep crashing with Bsod i get all kind of them
Memory_Management
win32k.sys, PAGE_FAULT_IN_NONPAGED_AREA
irql_not_less_or_equal
and so on while i was typing this msg i had one crash and i was nt even doing anything apart from typing here.
i would love to get this pc fix but dont know how i just did a fresh install of window 7 and it seems to made it worse only use one 6970 because i thought crossfire was causing the issue.
sometime when i have Bsod pc would nt even start up it seem to power up but no display i had to keep restarting it and than it will work,
is there a possibility i can send this to pcs and pay for the repair ??
i took it to pc world but they would repair it as its not bought from them
its really frustrating that why i was thinking of just getting a new one but i am open to suggestions. thanks
mantadog
The trouble is, re using parts from the old build is risky if you don't know exactly whats causing it. So you buy a 100% new rig and just bin everything else.
faihaf
I agreed with you thats why I am here to get some recommendations I know nothing about current market and what is out there. So please help me with a bulid
Stephen M
I suggest you call PCS and discuss it with them, they will fix it but if out of warranty it could be expensive.
faihaf
ya i did called them but they told me as it outside the warranty they cant help me, it is a bit disappointing as you can see i am loyal customer still willing to by from them i hope they can start fixing pc which was bought from them,
i have seen this build in an other post i do really like it. what you guys think is there anything missing or room for improvement or anything i should change
InWIN G7 BRUSHED EFFECT DARK GREY CASE
Intel® Core™i5 Quad Core Processor i5-4590 (3.3GHz) 6MB Cache
ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
8GB Kingston DUAL-DDR3 1600MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - DVI, HDMI, 2 x mDP - 3D Vision Ready
1st Hard Disk
250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk
1TB WD BLACK WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
NO OPERATING SYSTEM REQUIRED
DVD Recovery Media
NO DVD RECOVERY MEDIA REQUIRED
NO OFFICE SOFTWARE
Promotional Item
FREE RAINBOW SIX OR ASSASSINS CREED with select GTX 9 Series GPUs!
Quantity
1
price 756
faihaf
or i could go with this £684 as i already got a hdd and a blue ray i will save £74. i dont see 1 tb hdd and dvd writer good value for £74?
1st Hard Disk
DVD Recovery Media
NO OFFICE SOFTWARE
Promotional Item
Quantity
1
£684
Stephen M
Both builds look OK. Is your current SSD working OK, you could get a rig with just a basic drive and then add that and your WD, that would save a bit more, not sure if it would be enough to go for the GTX980 but that would be nice if you could manage it, there is a notable performance difference between that and the 970.
faihaf
thanks for the input my current ssd is seems fine but its too small bf4 alone take like over 60 gig which mean i can only install one game at a time so thats why i was going for new ssd. when i try to edit my quote it does nt show the option for gtx980. could you please make a build configuration for me with gtx980??
