So, I took apart my laptop and was changing the thermal paste (First time for this laptop)
When I noticed... The gpu seemed to be soldered to the heat pipe... Is this normal?..
Or did after a prolonged use the gpu got so hot it just attached itself to it?
And example:
If the gpu was still attached to the laptop.. you'd be able to lift the whole thing up just by lifting the heat pipe..
It detached easily from the cpu but gpu.. I had to put it back in place as it was...
And example:
