Just about possible for very high/ultra settings. There are some games that have beyond-ultra settings (render scale, SSAA, etc) that will bring most PCs to their knees, while some games will just inherently go below 60fps on the higher settings in some situations and no amount of money will fix that. So any PC that you buy, if you whack all the settings on all games up to the very highest they will go, you might find it unplayable. An i5 and a GTX 1060 6gb should handle most games on ultra though.£700-800 on my next pc, i want 60 fps on most 1080p max setting, is that possible with this budget?
