Hi All, I would really appreciate your help.
I recently received my new desktop, I have got one of my Samsung monitors to plug in to the graphics card and working as it should but when I plug the HDMI from my other monitor (same monitor) to the motherboard HDMI it wont detect it, am I missing a step? they worked perfectly on my old computer.
Here is my spec if it helps:
CaseCORSAIR OBSIDIAN SERIES™ 500D SE CASE
Processor (CPU)AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4)
MotherboardASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGBReady!
Memory (RAM)64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
Graphics Card6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VRReady!
1st M.2 SSD Drive512GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIETPower
Cable1 x 1 Metre UK Power Cable (Kettle Lead)
Processor CoolingCorsair H100i RGB PLATINUM Hydro Series High Performance CPU Cooler
Wireless Network CardWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz
PCI-E CARD + BT 5.0USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
Your help would be much appreciated.
