joker375
Hello all
I am curious about something. When I first got my PC from PCS there was a program installed called EPU 4 Engine which allowed you to select either Max Power Saving mode or High Performance mode. When I set it to Max Power saving mode the rear case fan would sit around the 1900 RPM mark when I was browsing the web. However said program would always cause my PC to hand at shut down (another story) So When I called PCS the recommended that I remove the program completely as they have heard quite a few reports of it causing problems on peoples PC's and that I should allows windows to control the power needed for things I am doing I.E Gaming etc..
I uninstalled the program and so far my PC has not Hanged at shutdown but I have however observed my rear case sitting around the 1997-2050 RPM mark when I am only browsing the web etc... Does this speed seem extremely high to any of you guys or am I Just finding faults when there aren't any?
Any responses will be greatly appreciated !
