Everon
Hi guys.
A few years ago I bought a PC from PCS. The motherboard is the ASUS P8Z77-V which is in a coolermaster CM 690 II Advanced case. It currently has the default fans that came supplied which is 1x140mm at the front, 1x140mm top, 140mm at the back.
The problem I have is that I want to fit a new fan on the front which is a Noctua NF-A14 FLX. Now the Noctua states it needs 12v but the motherboard states that the CHA_FAN headers have +5V ( the pins show GND,CHA FAN PWR, CHA FAN IN, 5V)
I am not sure what to do or if I can use the fan. I have read many sites inc toms hardware but cant find an answer. If you guys can give any advice I would be grateful.
Cheers, Jay.
Cheers, Jay.
