Case Fan
ImACookie
Hi everybody,
i want to install a fan into my PC case "NZT 410 Phantom gaming case" and on the top is two slots one it came with the other it doesn't and my GPU hits 70C when gaming in 1366x768 resolution highest settings and around 54% fan speed on the GPU so i thought eh i'll stick a fan in since they're cheap.
I found a fan that fits the case which is this one http://www.amazon.co.uk/NZXT-FN-140...e-Case/dp/B0039825LW/ref=cm_cr_pr_product_top
But im kind of confused as of connecting it would i have to wire it round the back of the cable management or just plug it into the mother board? Just very confused to where i connect it, if somebody could explain that would be fantastic.
Thanks!
P.S Merry christmas all
ImACookie
Do u know what type of connection it has? 3pin or 4pin pwm or molex? I don't know if u know but you can get much better fan/s like the vipers - http://www.amazon.co.uk/gp/aw/d/B005O6519A/ref=mp_s_a_1?qid=1356392219&sr=8-1&pi=SL75
These are great I have them in a push and pull config and you can't beat them
The fan it's self or the computer? The computer im not sure exactly where i would plug it into so i could check but my other fan on my PC is similar or if not the same so i assume it's the same connections as this fan i put.
The fan i selected has a 3-4pin Molex connection
Thanks!
