Case Fans and Source ?
Hello everyone, 1st of all sorry for my english, i'm not english native.
Second of all, i've ordered a desktop from PcSpecialist and i have a few questions.
1. The CASE: i see it has 2 fans included and i added and extra fan on top. The Corsair H115i has 2 Fans+the other 3 it's a total of 5 fans. Is this enough for my specs or should i look for a bigger case? On the other hand i was looking at some other cases in the range of 130 pounds and it doesn't say if they have any fans included or not. If it's possible can someone recommend me a bigger case with some fans included in the range of 70-130 pounds ? Or Another case that has 2-3 fans included and i can add 2 more ?
2. The SOURCE: I wanted to add the Corsair 850W but when i selected it in my specs it was with white, i'm not sure what that means. Is it out of stock ? When i click the question mark next to sources i see i can select the 850W source. I know 750W it's enough but since the RTX 2080 TI consumes around 300-350 W i would feel more comfortable having some extra watts.
EDIT: I'm asking because I still have time to amend my order.
EDIT 2: I was looking at FRACTAL MESHIFY S2 BLACKOUT TEMPERED GLASS which has 3 Dynamic X2 GP-14 included and i wanted to add another 3x Corsair LL120 RGB Led Fans. (that will be a total of 8 fans, tell me if that's a good idea ) but it still doesn't let me select the 850W source :)
Thank you !
These are my specs:
CaseNZXT H511 MID-TOWER GAMING CASE (BLACK)
Processor (CPU)AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4)
MotherboardASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE DDR4 3200MHz (2 x 16GB)
Graphics Card11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
1st M.2 SSD Drive500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Extra Case Fans1x 120mm Black Case Fan (configured to extract from rear/roof)
Wireless/Wired NetworkingWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
Operating SystemWindows 10 Professional 64 Bit - inc. Single Licence [MUP-00003]
