Hi, just wondering what case fans PCS supply as their 'additional case fans'. I know they're corsair, but what type? I'm looking at adding an extra fan or two, and am wondering what PCS use to determine where in the case they would be best suited.
Looking at them, they look like high static pressure fans. If that's the case, I should purchase two high airflow fan for below the GPUs (intake) and above the blueray (extract), and move the high static pressure fan to below the hard drive bay. This on a Corsair Obsidian 750D.
Thoughts much appreciated! Thanks. :sailor:
Edit: also, there aren't enough 4 pin headers to connect all the fans to the motherboard, so one of the three will need to be connected via molex to the PSU and so lose the mobo speed control. I'd appreciate advice on which would be best for this, the options being a fan I taking from the bottom straight up to the lower GPU, a fan intaking up into the hard drive bay, the bay having excellent venting to the side which goes towards the GPUs, or a fan extracting above the blueray drive bay, although I intend to lower the drive to the lowest of the 3 bays to assist in cooling. Thanks once again for your input!
