SmokeDarKnight
Hey guys, just wanting to make sure this sounds correct.
I ordered my PC with "I have my own graphics card" so it looks like the cables are coming from my Modular PSU which are labeled Type 3 at the PSU side so PSI-E or something on the other side to plug into the GPU whether it 6/8 pin or what ever.
What i have done for SLI is connected an identical cable into the next available port in the PSU, in the same line as the existing cable and pulled it through to the same place.
Does that sound correct?
Then i plug in each GPU to the Mobo, connect the cables from the PSU, attached the cable with the SLI strip provided with the Mobo.
Is it that simple? Is it best to get one card working first or just go for the SLI of the bat?
I;ve read the manuals etc but theres so many variables.
Any comments appreciated.
Mike
Mike
