joker375
Just thought I would post this if the question of Will this cooler be Enough? is on your mind when creating your PC
I currently use and AMD FX processor with the Triple Copper Pipe heat-sink and fan from PCS and IT seems to do the job fine highest temperature I clocked the CPU at while Playing Arma 2 for over an hour and a half was 31c Which to me seems really good as I has TS3 running as well so If you guys are wondering yes the cooler is good !
