1. I see what you mean, when I looked at it just looked like a glue-y substance, could it be a bit of spillage from the heat paste job? I never spilt anything on my laptop (knock on wood), if anything ever got close it's definitely not anywhere near that location. The screws are all black, I think the one looks silver because of the lighting in the pictureMatte, I also don't know how your specific chassis should look like internally, but 3 things caught my attention:
- Does the CPU (or is it GPU?) heatsink look to be melted? Or maybe something spilt on the top of it and fried with heat? There's also a screw with a different colour (instead of the default black), but it shouldn't be a problem if it's the same size and length. The only heat pipe that goes that the same heatsink also looks a bit bent, but I might be seeing it wrong because of the picture.
- In 3 ends of the fan heatspreader, there's a foam near the holes (which is expected). However, on top of the foam (or glue) there should be some kind of plastic cover, to make the airflow go directly out of the laptop, instead of back inside the case. It might be that the cover is sitting on the laptop's removable back, but not sure.
- One of the fans is a bit dusty. Not crazy dusty, but that would prevent the airflow a bit.
I found a picture of somebody else with the same model and theirs looks like this
Image url *clikc*
who has the same problem and appearntly another company using a gtx 1080 gpu installed an extra bar to connect the other heatsink to the cpu too
Image url *click*
2. The plastic cases are indeed attached to the removable back
3. Thank you, i cleaned it a little bit more yesterday
Should I come to the conclusion that I need a better/different/replacement heatsink?
