I've got an I7-3770K CPU and at the moment it is running at stock speed of 3.5ghz.
This CPU has a turbo up to 3.9ghz, do I need to enable the CPU Level UP in the BIOS in order to utilise this, at the moment it is disabled.
you would need to enable it to utilize the feature , but before doing this give tech support a call & let them guide you through it as mistakes are easy to make in the bios & hard to rectify , so call them up to be on the safe side
