Hi, I have had the same problem for the last month and have struggled to find a permanent fix online.
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-3820 (3.6GHz) 10MB Cache
Motherboard ASUS® P9X79 PRO: INTEL® SOCKET LG2011
Memory (RAM) 16GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(4 x 4GB KIT)
Graphics Card 3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
Processor Cooling - INTEL CERTIFIED LIQUID CPU COOLER FOR SOCKET LG2011 (£79)
Win7 64bit
(if you need more information ill get it)
I think the liquid cooling system is not in full physical contact with the CPU, I am pretty inexperienced with handling parts so i've tried to refrain from touching anything except from changing the thermal paste (cleaned properly with the formulas etc).
It started suddenly when i heard my fans speeding up and i could not understand why, i checked my load and it was fine but my temp was peaking at 85°C.
I checked my liquid cooling and it seemed fine. so eventually i ended up changing the thermal paste to arctic silver 5 (the temperature change was too sudden but i tried it anyway) this did not make much of a difference.
I checked to make sure if it was physically attached ok and it was.
Now i am idling at around 55°C, my temps spike so bad for no reason even things such as loading videos/downloading etc. It seems the smallest activity spikes the temp.
I read sometimes the liquid cooling radiator sometimes gets clogged so i cleaned it even though it was not bad. i also read that sometimes the tubes clog or get blocked? how could i test this?
Basically any advice right now would be greatly appreciated as i am worried about my PC.
thanks in advance.
Win7 64bit
thanks in advance.
