Crackling Audio
Hewhoist
Purchased a new laptop a few weeks back, Had purchased some m2 drives for it so asked for it to come without Windows 11 and when it arrived installed the new drives and put on win11 along with all the drivers from the PCSpecialist however I'm still suffering crackling with audio. Not entirely as I can watch Prime/Netflix without issue however YT and VLC both suffering some crackling/popping audio. I've reinstalled the audio drivers to no effect. Any suggestions welcome before I contact PCS for help.
Thanks
Hewhoist
Could you post the spec from your order page (removing any personal information) please? Just so we know what system and chassis we are dealing with.
Have you tried headphones? Does that stop the crackling or is it regardless of how you listen? Are you watching Amazon and Netflix via the browser or using apps?
there isn't any crackling through my headset. I'm not always wearing one however. I use apps mainly but I do watch downloaded files
Hewhoist
Chassis & Display
Ionico Series: 16" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 14 Core Processor 13900H (5.4GHz Turbo)
16GB Corsair 4800MHz SODIMM DDR5 (1 x 16GB)
NVIDIA® GeForce® RTX 4070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
256GB PCS PCIe M.2 SSD (3000 MB/R, 1200 MB/W)
AC Adaptor
1 x 230W AC Adaptor
1 x 1.5 Metre Cloverleaf UK Power Cable
Battery
1 x Ionico Battery 73WH
VAPOR CHAMBER ADVANCED COOLING
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 + BT 5.0
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
Keyboard Language
PER-KEY RGB BACKLIT UK KEYBOARD
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Keyboard & Mouse
Webcam
INTEGRATED 2.0 MP FULL HD WEBCAM
That's weird. Given it disappears with a headset points to there being an issue with the speakers...but the issue only being present with certain apps makes me not sure.
First thing I'd do, assuming you haven't already done so, is uninstall Norton. It probably won't make a difference but it can cause issues and it's better just to get rid....Windows Defender is better anyway.
Only thing I can think of is apps like Prime and Netflix perhaps have differing audio settings...if there's an issue with one of the speakers, maybe a certain frequency or something sets it off. No clue if you have done this but, if it was me, I'd go into VLC and try playing with the audio settings to see if that does anything. Maybe try downloading a different video player just to test if it's VLC or something else (I have used VLC in the past but I never found it to be a great video player)...something like GOM player:
It's free and is safe to use (I used it myself).
Not heard of that one but does look extremely good by reviews and a very modern interface which VLC is unfortunately lacking still, thanks for sharing (y)
Hewhoist
Are your headphones USB or mini jack? Have you tried them in the same port the speakers are using?
They are usb-c. I haven't tried through the jack. Good suggestion for troubleshooting it. I'll find a pair and put them through the jack. I'll download the GOM see if it removes the issue. Norton was off from the start I'm not a fan of it.
If they're usb, then they're likely bypassing the on board audio and using their own in built DAC
If you do have a pair of standard jack headphones or another pair of speakers, would be worth trying them in the same port.
Alsotry the headphones in the case port if you have one just to see if the issue is there also
