jimbojones0145
I was just wondering if there was anywhere to find detailed specs on any PCS parts that PCS are using in there builds ? anyone got any info ?
If you click the question mark next to the component you're interested in, it gives further information.I was just wondering if there was anywhere to find detailed specs on any PCS parts that PCS are using in there builds ? anyone got any info ?
Best bet on those parts is to drop PCS an email. I believe they're more generic parts so might be worth spending the extra and getting the better AIOIf I google the PCS parts it just sends me to the check my spec on this forum and it doesn't really have a place that tells me more about it. like can I change the rgb on the fans and the cooling block to match the system theme
