My Optimus V 17's display panel has developed an issue, where the panel does not work or has very weird artefacts on screen, depending on the precise angle the screen is from the motherboard. I've another identical machine that works fine.
The issue seemed to get worse over time, and its now got to the point that I can barely find a place it works properly in. When it is working, it is 100%, when it's playing up, the panel is either blank, has a static image with artefacts all over it or flickers badly.
I suspect that this is an issue with the cable between the panel and the mobo, but I'm not sure. I have the following to ask :-
1. Is there a full disassembly guide available for this laptop?
2. Does anyone know if the cable is detachable at BOTH ends?
3. Has anyone else had this or a similar problem? Did it turn out to be unfixable?
