Dust Cleaning
Hi All
I wonder if anyone can help me, I've made a pc build using the PCS configurator and part of the build has a reference design graphics card, can any one tell me if its easier to clean than a non reference card? Also whats the best way to clean a reference card?
many Thanks in advance
tom_gr7
Life Serving
compressed air is ya best bet for cleaning all pc components, just blow out the dust, when everything is powered off ofcourse.
if ya concerned about dust, i'd certainly think about getting a case fitted with dust filters. OR even adding extra dust filters once you get ya rig. Rakk told me about demciflex filters, they are magnetic and really good, just stick straight onto the outside of the case. http://www.demcifilter.com/
