Kai121
Was getting annoyed at constantly having to go into power options to change bwteen Low Performance and High performance (The toolbar options only give you High or Low plus balanced) so I went on a crusade on Google and found this gem:
http://www.howtogeek.com/howto/windows-vista/create-a-shortcut-or-hotkey-to-switch-power-plans/
Shows you how to set up an Icon plus set a Hotkey command to switch!
/me is much happier now
