Hi. Sound issues out of nowhere. Noticed it this morning watching You Tube. Laptop arrived last week and is working perfectly.
I've Googled and found this thread: http://www.techspot.com/community/t...io-output-if-it-is-not-a-sound-effect.178881/
Have tried this:
"I had the same echoey issue and mine was resolved with making sure the windows sample rate was the same as the Realtek HD sample rate. Both should be set to 16bit 48000Hz. Go to Control Panel > Sound > Speakers (Realtek Audio Device) > Properties > Advanced then select the above sample rate from the drop-down menu and apply. In the Realtek Menu (click on speaker icon in bottom right of Windows) Select the Default Format tab then make sure the same sample rate is listed in that drop-down menu."
Hasn't solved it.
Anyone have any ideas what else to test/change?
Thanks
Have tried this:
Hasn't solved it.
Thanks
