Elimina Pro keeps reverting refresh rate to 60hz
Airwalk2k8
Recently bought an Elimina Pro which has been working great, however the refresh rate keeps changing back to 60hz when I unplug the charger, when I PLUG IN the charger having reset the refresh rate back to 240hz and I also noticed it changed from 240hz to 60hz when the battery reached full charge... I have done a lot of googling and nothing is working. I have set my BIOS to dgpu as I don't want to use Intel's gpu and I have uninstalled Intel Arc. I'm using my RTX 4060 as the gpu for everything and have changed Nvidia control panel settings to reflect this.
There are no refresh rate settings in Intel Graphics Command Centre. I only have a balanced power plan option for some mental reason.
I'd just like my laptop to stop reverting to 60hz. I mainly use the laptop plugged in, so its just very annoying if I unplug to go use somewhere else in the house temporarily and its even more annoying when it goes to 60hz when I plug back in. I'd just like constant 240hz so I don't have to keep manually changing this in advanced display settings when playing games.
Chassis & Display
Elimina Pro Series: 16" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i7 10 Core Processor 13620H (4.90GHz Turbo)
32GB Corsair 4800MHz SODIMM DDR5 (1 x 32GB)
NVIDIA® GeForce® RTX 4060 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
Integrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor
1 x 230W AC Adaptor
Battery
Elimina Pro Series Integrated 62Wh Lithium Ion Battery
LIQUID METAL PERFORMANCE COOLING
Nahimic by SteelSeries 2 Channel HD Audio
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
Keyboard Language
ELIMINA 16" SERIES MULTI COLOUR BACKLIT UK KEYBOARD
Windows 11 Professional 64 Bit
Windows 11 Professional Multi-Language Recovery Image - Supplied on USB Drive
Firefox™
Notebook Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
