I use less than 4GB in pretty much all the situations I use it for, so that should be fine. I don't actually know if this one is user upgradable in terms of RAM, and if it is you'd need 1x8GB as it will only have 1 slot.[/QUOTE]
Are you sure? I thought the same because of the slim design, but in the configurator it says 2x4GB.
http://i.imgur.com/4K4INKD.png
