Entry level pc
boxed78
Hello, I'm looking at getting my 1st pc and moving over from console and any advice would be greatly appreciated. I'm currently looking at the pre-built titan 70 from pcs the specs are basically
  • AMD Ryzen 7 5800X
  • Windows 11 Home
  • GIGABYTE B550 GAMING X V2
  • 16GB Corsair VENGEANCE 3200MHz
  • 8GB NVIDIA GEFORCE RTX 3070
  • 1TB SOLIDIGM P41+ GEN 4 M.2
So my questions are
Would this be a good 1st gaming pc?
Would it be upgradable in the future?
What monitor would you recommend? (Budget of around £300)
A
On pre-builds what kind of delivery time is there?
Thanks in advance
Sorry complete novice when it comes to pc's
Ekans2011
  • AMD Ryzen 7 5800X
  • Windows 11 Home
So my questions are
A
Thanks in advance
Hi, what will you do with the PC?
What is the resolution of your choice? Max budget available?
Honestly I would never buy a DDR4/AM4 platform in 2023. There's no way to upgrade a build like that.
boxed78
Thanks, it's just for gaming really my budget is around £1200 ideally, any suggestions?
Ekans2011
Hi again, actually I can't suggest anything less than this.
It should be sufficient to play at 1080p, with some room for future improvements.
AMD Ryzen 5 7600X Six Core CPU (4.7GHz-5.3GHz/38MB CACHE/AM5)
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s)
32GB Corsair VENGEANCE DDR5 5600MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 4060 - HDMI, DP, LHR
Graphics Card Support Bracket
NONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti AND ABOVE)
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
CORSAIR H100i ELITE RGB High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £1,383.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/atdMtavC5u/
boxed78
Microsoft® Edge
Thanks, much appreciated
