My internet will be transferred to Sky tomorrow. Just incase they give me any bull about my line capabilities if I have a problem after the 10 day "stabilising" period, I have been taking screen prints of my Speedtest.net results over the last couple of weeks to have a record of my current connection (just under 2Mb/s).
I happened to look at my internet connections in the Network and Sharing Centre and saw the following results (I currently have my PC connected via ethernet cable and via wireless card):
Ethernet speed: 100.0 Mbps
Wireless speed: 135.0 Mbps
LAN
Sent: 1,340,000 Received: 7,044,000
WIRELESS
Sent: 388,000 Received: 340,161
My questions are:
1) Why does the ethernet speed show slower than the wireless? I thought being directly connected by cable would be better.
2) Is it good, bad or doesn't it make a difference if I have ethernet and wireless both enabled at the same time?
If you're wondering, I have both enabled as a sort of belt and braces in case I get a bit of a glitch in one of the connections I thought the other connection would keep me connected. So I guess Q.3) would be: is my thinking right or wrong on that?
Cheers!
LAN
WIRELESS
My questions are:
Cheers!
